Richard K
- Pacific Grove California
Dear Forum, I had a good day and have dismantled by non running Jota with all the bits that need to, ready to go to the powder coaters. Satisfied with with my endeavours, I have set about the engine and subsequently had a fairly disastrous day and as a consequence I am looking to you all for salvation. Firstly, I had anticipated doing a top end overhaul of the engine and planned to stop north of the crankcase. I was taking the cams off when the half moon shaped doo hickie that holds the cam shaft in place dropped off mid disemmbly and dropped into the only FUCKING hole in the garage that would have caused me so much pain- which was right down the cam chain passage and into the bowels of the engine. Anyway, I have a magnet on a pole and so went fishing for it. I got a bite and thanked the lucky stars only to discover it wasn't that but the broken half of the cam chain tensioner, that at some point prior to my ownership has obviously parted company with it's upper end (which was still held in place by the retaining bolt. I also noted that at some point, the now liberated camchain has started to bite (about a mm) into the crank case. The damage that was sone to the crankcase looks sufficiently trivial to not cause problems. So now my dilemma. Do I go into the bowels of the engine to try to find any damage down there ? Or do I trust to good luck and hope that the half moon doohickie can float around in there in perpetuity and that the broken half of the cam chain tensioner has done no harm in there. Thoughts please. Oh and for good luck, I am also asking- while I am this far in, what would anyone replace ? The head looks spotless, the barrels are as smooth as a babies bottom and the rings looks fine, I havent had it running yet, but it turned over nicely before I dismantled it.
