It appears (trying to work out the diff measures used) that the Bosch brushes (ebay link) are a bit longer than what Brett has advised, but doubt if this would be a problem (as long as spring doesn't bind)?martymoose said:Getting back to the topic, do Bosch brushes fit sjce.
Youse blokes need to wipe your chins, the bullshit is dribbling out
Dellortoman said:The Metric system was devised in Europe in around 1800 for ease of calculation. Everything being in multiples of ten. By the time Australia came on board with it, electronic calculators were becoming readily available so ease of calculation didn't matter so much.
blab said:The French are great, they gave us democracy, the metric system and oral sex.
And standard configuration for modern rear wheel drive car. If I remember correctly this arrangement engine at the front, then clutch, gearbox, cardan shaft and then rear axle was invented by Panhard & Levassor at the very beginning of 20th century. All of my cars have this arrangement.blab said:The French are great, they gave us democracy, the metric system and oral sex.
MotoJouni said:And standard configuration for modern rear wheel drive car. If I remember correctly this arrangement engine at the front, then clutch, gearbox, cardan shaft and then rear axle was invented by Panhard & Levassor at the very beginning of 20th century. All of my cars have this arrangement.
At least many imperial units are bound today to metric units using coefficients. There are accurate determinations to define units. These methods have changed over the years and most accurate ways are used. These most accurate methods are very expensive and mostly used on some very expensive laboratoriums.
Some units are derived from other units. For example Newton comes from kilogram, second and Earth's gravity.
Mostly there are devices that carry the unit with certain uncertainty and measuring instruments are manufactured and calibrated according to these.
Better you check your facts as Wah Wah is from Burma ( Myanmar as called nowdays ) so I know for a fact that they are metric country.Paul Marx said:The metric system is a french invention and a produce of the Revolution. It was brought into use in 1795 after the definition of the meter.
It can be incorporated into the search for universal values from which stems the universal declaration of human rights.
The metric system is the base for the International System used all over the world except in the USA, Liberia and Myanmar.
martymoose said:Wow that's impressive 3 pages of chinwag and we have found out the origins of oral sex but we still don't know if Bosch brushes fit in an sjce starter.
Technical forum eh?
Legs said:Time to indulge in a bit of self-assessment Chris, the rest of us were thinking 'soixante-neuf.![]()
