piranha-bro2
- Melbourne
Surely weld would take up any space left through shrinkage??
Dellortoman said:Just thinking more on the possibility of casting pieces to insert. It looks like it might be possible to reproduce the fin spacing by taking a mould of the finned area on the un-damaged side use that to make a pattern for the damaged side.
However, given the size of the hole in your case, you'll need to allow for casting shrinkage, so it may not be quite that simple. If you know anyone with a 3D printer, you could make a pattern using copying methods, then get it scanned, scaled up by whatever shrinkage factor deemed appropriate*, 3D printed and use that to cast your alloy. Or if you know someone with the gear to 3D print in aluminium alloy, it'll save a step in the process.
* I've seen aluminium casting shrinkage figures quoted between 1% and 3% depending on the type of alloy and size/shape of the part.
On second thoughts, your Plan A might be simpler. Find a set of rubbish cases that you can carve up![]()
Tippie said:Just noticed no oil cooler on it. I never understood the need on an SF/C. Had mine in over 40?s heat in Australia a lot and it never ran hot, racing likewise. I fitted one to mine at the first rebuild (because the SFC had one) and had to tape over it as the bloody thing ran too cold in a West Oz "winter". The stubs are blanked off now, I?m considering trying to use them for a filter if it can be done neatly (unlikely with my skillset).
Good to see you so positive regarding the repair, Piet. Most people, lacking your resources, would just give up on trying to restore it to originality. It is a very special bike.
sfcpiet said:If it wasn't such a nice bike to ride, I might have decided to just rebuild it as a static display.![]()
