calculating valve shim thickness range BEFORE installing cams and valve springs?
hi Paul ,i always tap the replaced valve and collets with a good sharp tap, hide mallet is best just to make sure everything is seated. also get you self a better ranged of shims and use the sheet of glass, emery tape and cutting oil and you will be able get the perfect setup for your cam clearances.
happy new year your bush mechanic Andy  ;) ;) ;)
