A little while ago I bought a 1000c3 , Impeccable visually, someone spend a lot of money.
But, low compression on 2 cylinders, I cranked and noticed the hissing, and a compression test confirmed this.
I pulled the head, chain was intact, and connected, but missing the circlip lock, incredible yes !
Issues with the head gasket . Blow by, head bolts were loose, think seems someone started repair, but stopped.
Previous owner died, so I have no history, bought it from an estate.
I have serial #1543.
The timing chain has markings on it, it says Regina extra, and appears to be the original chain or an original replacement , it's very pretty, and well made. I did get a hold of a new Regina c121hcs, but I cannot get it connected, even after pulling the tensioner blade, and the tensioner , it's short by a minute distance. The old chain fits well. I read on Breganzane that there was a production run with this problem.
I would prefer to mount the old chain, so I need the closing link, or at least the circlip.
Where oh where can I find one ?
Clearly the newer Regina chains use different links, so that is not an option.
Call if you like.
Henri @ 415 302 8416.
I am in San Francisco, originally from Holland, it's where the Laverda love comes from..
Call if you like.
