Men: I use that term loosely on this forum. So here is the deal. I purchased a 3c with axtel cams(sp) just did a valve adjustment and noticed the cams where marked 4/c. I have seen 4/c cams and own a pair of 7/c cams for 180 triples. These are not 4/c cams. Much more duration. Big thick cams with 4/c lift. 1) Are axtel cams just reground 4/c cams? Looks that way to me. Cam timing. Are there different cam sprocket wheels for different cams? Bike runs real good @ high rpm anything over 4000 but seems to grab revs slow (lumpy) i know typical of big cams but i feel the bike should spinning up faster. Cam timing or maybe ignition timing? Ignition system is AUS a little old school early aftermarket piece seems to work fine setting on #2. Hmmm? Any thoughts? Cheers!
