B
Bearsaregood
Guest
The basket case 750SF2 is finally getting some attention. The parts box contained two cylinder heads. The previous owner assured me that the newer looking one, loosely fitted to the barrels, is a 650 cylinder head with spacers machined from billet mild steel, and attached to the inlets to allow standard 750 airbox hose connections. The second head, covered in 25 years of dust and oil, is locked solid, and currently bathing in kero in an attempt to salvage it. I have found it impossible to get any info on the 650, so I have a couple of questions before I take the two heads down:
Are parts for the two heads interchangeable. without dismantling for proper measurement, they appear to be very similar.
The Green book says that camshaft removal is possible without Laverda special tool No. @#*&!%$&. If anyone has a photo of the tool or has removed camshafts without using same, I would appreciate any advice given.
Help!
Help!
