ok, I'll bite.....
mark your twist grip with a baseline;
then mark your throttle housing with throttle closed, 1/3, 2/3's, and wide open
starting circuit and initial idle is choke jets, pilot (idle) jet, and idle mixture screw. Make sure your choke plunger rubber tips are in good shape, and close FULLY when shut off, otherwise all your other jetting efforts will be wasted. Pilot jet start around 60, if rich, go 57.5 or 55's. Idle mixture screw, you will know you have the correct pilot jet when it idles best at about 1 and one half turns out
1/3 to 2/3's throttle, the biggest changeable item to affect mid range is needle and needle jet. Needle jets AB 265, needle K 1, start in middle notch.
Main jet depends on properly getting everything else right, but essentially by he time the bike is on wide open throttle is when the main jet size is the real issue. You are going to have to do some wide open throttle runs. Start at maybe about 128 main jets, run wide open throttle, see what happens, bike runs well, big bogs?
best easiest ad quickest to get this right is with a wideband exhaust sniffer on a dyno, make sure you check closed throttle, 1/4 to 1/3 throttle. 2/3 throttle, and wide open throttle, a lot of dyno operators just want big wide open numbers, useless to you for daily riding and tractability.
If you don't have access to a dyno, at wide open throttle, back off to about 2/3's throttle, if the bike doesn't accelerate harder when you back off and the needle lowers partially obstructing the main jet, you have it about right. Too big main jets will make the bike bog at full throttle, if backing off to 2/3's throttle (into the needle and needle jet) will result in the bike accelerating, go smaller on the main jet.
for your initial testing, leave the 145 mains in, run the bike at wide open throttle, observe whether it is puling hard and cleanly, or not, then back off to about 2/3's throttle and observe what happens, if the bike accelerates harder at 2/3's throttle your 145's are too big.
When you go smaller on the main jet, be careful to take occasional plug readings to make sure you don't wind up too lean, you want a nice tan coloured electrode, not black for too rich, or white for too lean.
Paul LeClair
ps also remember, 90 % of carb problems are something other than carbs....... before you start on the carbs, make sure ignition and ignition timing are spot on, adjust the valve clearances precisely, check for intake leaks, all BEFORE even touching the carbs....
