When making motorcycle tanks, Carbon Fibre, Kevlar and Glass fibre are materials used to reinforce resins.
So when a tank gets dissolved by modern fuels it is resin to blame not the reinforcing material.
Two most common resis in use are the Polyester Resin and the Epoxy Resin.
For some time now, I have been repairing and remaking some older aftermarket tanks that dissolved under the influence of modern fuels. These were mostly seventies products , Dunstal, Gus Kuhn, Bimota to name a few but these were all made in polyester and glassfibre.
Look inside your tank.
If the material it is made of looks like randomly spread fibres, not woven, than your tank has good chance to be dissolved. This material is called chopped glass mat and is always used with polyester resin. Polyester resin is not resistant to ethanol.
Most of seventies tanks were done like this.
On the other hand the Epoxy Resin has high chemical resistance. It was not so commonly used because of the price.
For my work I only use Epoxy Resin.
When my first piece was made took some cutoffs to a lab. They held in concentrated ethanol for two months and tested the ethanol for traces of dissolved epoxy. The result was negative.
Questions?
Questions?
