D
Davo
Guest
OK, so the first pair of new fork seals I fitted turned out to be so fat that the retaining circlip would not fit. No I did not measure their thickness prior to fitting - idiot that I am assuming that as they were bought for this purpose they would be the same as OEM. So, now I measure the other new pair and find them to be 7.5mm thick, parts book says they should be 7.00mm, go through the old parts bin and find the originals I had removed - 6.75mm, measure another set that I had ordered when the first new pair didn't fit and they are 6.75mm.
Inquisitive I start to research fork seals and in the very informative "Guzziology" Dave Richardson states that:-
1. Older design fork seals as were OE in our ancient forks were actually designed to seal against rotational movement rather than longitudinal and hence were prone to leak with the stanchion movement and that is why two fork seals were used per leg.
2. The newer design fork seals are much more efficient at sealing against longitudinal movement due to their tighter fit on the stanchion but because of this tightness also increased the friction between seal and stanchion and therefore increased stiffness.
He went on to recommend using a single seal only.
Now, the first set of seals I got were from a Guzzi dealer, the second (and correct thickness set) were from a Ducati dealer.
Should I use 1 each per side of the fatter "Guzzi" seals or go as per original with 2 seals per side?
Your expert opinions would be much appreciated.
