ceriani shockabsorbers rebuild information
Peerless
Hi fellows
Are there any information about the old cerianis, early 750, 1000, about rebuilding and modify them. is it worth the effort or is a replacement for Konis or hagons a better way to go. The wallet is on a budget as usual.
Cheers/ David
I can supply new damper rods and seals.  These are specially made items as the original seals are no longer avaialble.  Kit comprising of 2 rods and seal sets costs 143euros + postage.
Hagon? Doesn't really make sense replacing 40-year-old units with new 40-year-old items... applies to almost the same degree to Koni/Ikon.
If real suspension improvement is required, might be better looking into alternatives like Falcon, Maxton, YSS, Wilbers or even �hlins, depending on wallet capacity.
The answer to your question depends a bit on how original your bike looks or should look like. If everything appears like the factory setting of the early 70s a rebuilt could make sense. Piet has offered already seals and rods. Wolfgang Bitschnau (www.rmproducts.at) helps you with individual fitted chromed suspension springs, which can make old Cerianis really comfortable.
Dominik
Piet,
Could you show us some pictures of your kit ?
Thanks
S.
