Any electrical gurus out there. I have a charging issue with a 77 3CL. I have fitted a Redax alternator conversion which does not seem to cope with the lights or indicators being switched on. The battery is showing approx 12.6 volts at rest. On running the engine up to about 3K revs I get 13.5 volts but if I switch on the headlights or indicators the battery drops to 12.5 volts which will drain it given time.
The rectifier is a new electrex unit - the original one supplied with the conversion failed fairly rapidly - is this a clue as to a possible problem?
My electrics are relatively basic when it comes to alternators. Does any one with more in depth experience have any ideas on possible causes and how to check them out??
