pic attached.Greg Parish said:The crack at the camchain tunnel can be welded up.
cbertozz said:This sucker does appear to have a disproportionate amount of oil on it - is this the stud referred to?
Not the one I was referring to anyway.
I mentioned the stud at the front of the engine at the cam tunnel. The one you show is on the left side in front of the primary chain casing.
Look between downpipes 2 and 3 and you will find a nut where the stud passes through the head an cylinders at the cam tunnel.
