mikeringrose
- Market Harborough Leicetershire UK
Hi,
I have checked the points, timing, plugs and valve clearances and all appears to be fine. Runs like a dream but when dropping down to tickover sometimes it pops and cuts out. It restarts Ok and ticksover is normally OK. Also sometimes tickover holds at 1200 rpm and then slowly falls. Before I pull the carbs apart again I wonder how important are the rubber sleeves that go over the ends of the cables and on to the carbies? Mine are perished and cracked. Can this cause an air leak which might be the cause of my problem?
Kind regards
Mike
Kind regards
Mike
