Well Malcolm has been listening to all of you ( me in particular as have been hassling him to make for the RGS as I dont like the way the 180 pipes have to sit on RGS's ) so now following the release of chrome jota silencers from Malcolm Cox, Cox Engineering, development continues now with the release of purpose made jota silencers for the 120 degree range.
These are identical apart from mountings to the 180 range.
We have now designed the new mounting system to mount the silencers correctly onto the bike without the need to turn them upside down and have unsightly brackets hanging down.
There is a new mounting system in place which removes the old brackets like fitted to a 180 model, and replaced with drilled bosses with an 8mm thread which is almost identical to the genuine RGS original silencers.
There will be a fitting kit available which includes stainless steel polished mounting brackets and stainless fasteners to fit.
The stainless brackets which are laser cut, bolts onto the silencers and directly onto the existing rubber blocks on the footrest hangers as the originals.
The holes in the brackets are longated to allow for the "rise" of the silencers to be adjustable and to allow to get levil from the back.
The adjustment also allows a good gap for pillion footrests, identical to the factory originals. It is ultimatly the angle of the collector which determines the incline of the silencers.
More importantly, the development has also extended to include brackets similar to the genuine item, for adding the standard bracket which stops the mainstand hitting the underneath of the silencers every time is is pushed off the stand. The continued banging on the silencers from this and rubbing on them while riding will add to the possibility of cracks in both the silencers and collector boxes.
These are the first ever silencers ever developed and made to actually fit the 120 models correctly including mounting kit and mainstand bracket.
Any enquiries to Malcolm Cox, Cox Engineering.
coxeng@gmx.com
telephone international........0044 1789 400606
FAX International................0044 1789 400808
UK. Telephone....................01789 400606
FAX...................................01789 400808
Callers are welcome by appointment and orders can be collected or sent worldwide by couriers.
coxeng@gmx.com
