Spub
In dismantling the carbs on my newly acquired 74 SFC, I noticed quite a bit of wear on the slides. Beings as the bike appears to have been run with the stock bellmouths rather than air filters, this is not too surprising, but it did have only 5K on the clock.
Does anyone know of a source for chromed or otherwise treated slides for a PHB 36 carb? Can the worn slides be cleaned up and chromed? I want to keep the PHB body, so don't want to install a new carb, and the bike will not see huge annual mileage.
I had a Bevel 900SS that ran on bellmouths, and I would remove and wipe down the slides now and then. Put 5K plus on that bike and there was much less wear on the slides, and this for a 40MM PHMs and an engine that sucked like a shop vac.
