wdietz186 said:The Ducatis use a 13mm with the same thread.would make the pull a bit easier at the expense of a bit less travel.
as far as I know they are very hard to find in good condition, and command a very high price
CLEMTOG said:"gold ones are rare nowadays, but black ones should be fine to find."
Are you sure lothar, and do you mean Brembo round capped ones?, as far as I know they are very hard to find in good condition, and command a very high price when they come from a breaker,which a used one will have done, and to find a new one ? I would like to know from where.
mauricejota7604 said:Ian you can still use your bike without it what model is it on?
I have about 600 mt's of dirt road before I hit the bitumen, and am a little cautious regards dust getting into the system. While I have the inner cover of I am replacing the final drive with a 530 chain and hoon sprockets as well (has the 630 set currently). All parts on the way.mauricejota7604 said:Ian you can still use your bike without it what model is it on?
