- Calgary, Alberta, Canada
I am getting to the stage of building up the clutch assembly from scratch, then the primary, on the 82 100 motor.
I happen to have kicking around a spare brand new set of Red's Kevlar clutch plates which I think I will use, and the stock steel plates only have 10,200 kms on them and should clean up fine. Everything in the clutch assembly/housing is otherwise stock and untouched.
on both my RGS and on my 79 1200 I basically turned the clutch basket and backer into swiss cheese, and then polished everything. I have to confess I haven't felt any real difference in the clutch operation before and after modification.
so, do I leave these 1982 1200 low mileage clutch castings stock and unmolested, or do I get out the circular table and go wild punching holes?
thoughts and opinion?
Paul LeClair
Paul LeClair
