SandPebbles
- Madison, CT U.S.A.
I've have a few questions regarding the clutch assembly of my '74 3C. When taking apart the clutch, I found a thick washer under each of the clutch springs...between each spring and the pressure plate. The washers appear to be an aluminum crush washer with the open side towards the plate. I have new springs to install and I haven't seen these washers on any parts diagram. Are they
supposed to be there?
The bike also has a hydraulic actuator for the clutch. I can only guess the previous owner converted the bike as I think the bike should have a cable actuated clutch (Bike is S/N 1592). I intend to keep the hydraulics but have read about the problems of the system leaking and building up pressure behind the slave cylinder and cracking the casing. One remedy I've seen referred to in the forum requires drilling and tapping the hose connection deeper so it threads into the slave cylinder thus sealing the fluid from the casing. Are there any diagrams, drawings or procedures out there that give any dimensions, thread sizes or depths for the fix?
Any help would be grateful...thanks.
