A stock Laverda clutch in GOOD condition will NOT slip, no need for triple-strength springs or any other fancy gizmos. Get just a little bit wrong, and problems can arise. Slipping clutches are mostly caused by worn basket or hub splines, causing the plates to over-heat and buckle and make matters worse.
By inserting an extra steel plate, the engaging surfaces of the clutch hub and pressure plate are reduced by the thickness of the extra plate. May not be an issue with worn plates, but might be a bit edgy with new ones that have just a little extra thickness compared to standard. Properly fitted, the anti-rattle springs do their jobs well. It pays checking the clutch hub for both wear on the engaging splines to the mainshaft and for a loose steel insert in that place. To cure a loose hub, I machine a groove on the rear where it mates to the gearbox bearing and fit an o-ring, just as in the 750 twins. This measure jams it up against the bearing and it stops rattling for quite some time.
For the life of me, I cannot understand why anybody would want a rattly clutch! :
The junk Ducrappi calls a clutch and sells to the pulic, would be turned down in any 2nd year engineering class, let alone make it into production anywhere else. Bad engineering through and through, unnecessarily loud and extremely wear-prone, about on par with bevel cranks. They're already admitting to lousy engineering imho, the newest Bolognese products run a wet clutch...
