- Calgary, Alberta, Canada
as I have been puzzling out the wiring on my 82 1200 TS Mirage project, and am currently wiring the new ignition, I started wondering about coil and spark plug polarity, and whether polarity matters.
after some internet searching, I came across this article http://www.chicagolandmgclub.com/techtips/general/574.html which suggests getting the polarity correct (negative, apparently) at the spark plug center electrode is worth 15 % spark energy.
I don't know if the 15 % figure is correct, but the rest seems to make sense to me, although electrickery has never been my thing.
In my 82 1200 TS Mirage build I have been trying to stick as close to stock as I can, and I am going to try and re use the low mileage original coils. Those coils don't have any polarity markings I can see. The dual coil has one black wire lead, and one green wire lead. The single coil has one black lead and one orange lead.
To wire the coils from the ignition, the triggered output from the ignition is going to be individual, the one to the dual coil is going to wire to green on the coil, the one to the single output coil is going to the orange lead. That wiring scheme would require the common power feed to go to the black wire on each coil? Will that give the correct polarity to the coil and plug?
anyone?
Paul LeClair
EDIT as my wiring harness is not yet fully completed and I can't yet power it, is there a test I can do on the coils with an ohmmeter to determine polarity of each of the black wire and the coloured wire on each coil?
anyone?
Paul LeClair
