shadowfax
- Manchester, UK
Last started just before Christmas, all I have done is take the battery off and charge it
It is a BTZ system with 2 x 042 Bosch amplifiers (resistors?), and a single coil, and a twin coil on a 180 degree 1200
So, no spark at the plugs. I have now gone through the wiring.
Kill switch fine and engine turns over without any problems, so I assume the battery is ok.
With the ignition on, 10 volts either side of the ballast resistors, 10 volts into the coils. I cant believe that both coils would fail at the same time
I understand that there has been other posts that discussed just junking the ballast resistors all together.
I hear all these post about change the plugs, I struggled to see why that would make a difference as I have had many bike that failed to start, flat battery, blocked carbs etc, but once the plugs where cleaned and the fault sorted they have started without any problem. Having said all thatI did put some new plugs in, with the same results. If there is no spark it will never start.
