Tech advice please on a low rev / small throttle opening misfire.
The bike is a Corsa, standard apart from Jota pipes, Witt + Dyna coils and Mikuni RS36s. I do quite a lot of miles on it in all weathers (well almost all...) and it has been running sweet as a nut until this morning.
After about 10 miles on the motorway, I slowed for the remaining 4 city miles of my commute and the bike was running rough, but in a consistent way that sounded and felt like one cylinder wasn't firing. If I opened the throttle it would pick up and accelerate normally on 3, then revert to the misfire when I closed the throttle. Wasn't keen to idle, not too surprisingly...
I'm thinking one idle jet may be blocked, but will check all the ignition wiring too just in case something is loose - does anyone have any other ideas or experience of this kind of problem?
Thanks in advance
Thanks in advance
