- Calgary, Alberta, Canada
I am the culprit who suggested Three Bond 1211 to Chris, I just used it on the engine cases of my present 82 1200 engine build. Thinking back, probably recommended to me by SteveB years ago, as I have used it in various previous Laverda engine builds.
someone mentioned "The Right Stuff", which is a Permatex product. I would NOT use that for Laverda crankcases, too thick, although the Permatex I Minute Gasket Maker, grey, seems finer, but I think either would be overkill for the finely machined faces of Laverda engine cases.
http://www.permatex.com/products-2/product-categories/gasketing/gasket-makers/permatex--the-right-stuff--gasket-maker-detail
Despite Harry Lime's statement to the effect that certain British engines were "designed" to leak, I will be using the Permatex black The Right Stuff on the oil pan gasket of my Triumph car engine assembly, as well as the timing chest, both of which are such crappy fitment and wavy gaps they pretty much always leak, but I think the black thick gooey stuff from Permatex has the best shot at actually sealing them. On another topic, I finally got the last of the machined Triumph car engine parts back from the machinist yesterday, I need to run out and pick up some of the gasket sealer.....
Paul LeClair
Paul LeClair
