CLEMTOG said:my money is on loose/sloppy slides in the carbs, would happen sooner if run without an air cleaner, and even quicker and easier to hear if run useing bellmouths or as the yanks call them velocity stacks.If that is the case, then a good long run at about 140kph, might even see you hole a piston,(would not want that) more likely at that speed than higher or lower, due to the progression of the carb.
Dellortoman said:Being in the clutch could also explain why it gets worse as the engine warms up. The alloy clutch drum expands more than the steel clutch plates. The increasing clearance means more backlash.
