Hello Lads and Red,
What fun to be had at the end of a Laverda crank, well fun has many forms.
Did extensive work on the heat issues to be dealt with on the IIS applications for not only Laverda, Moto Guzzi and Ducati also. Made a batch of hall effect sensors in the base shape of a Bosch reluctor pick up. Embedded in the pickup was a temperature sensor chip. Logged temperatures on the 120 motors and the 180 II's, did something different on the 180 series 1 motor however. First the Ducati, being a bevel, the pickup was in the crank case oil ie inside the crankcase. This S2 Ducati ( 1000 ) registered 120C inside the motor in stalled traffic on a very hot day. That is oil damage temperature and was typical for air cooled engines operating in Australian summers. Take note, it is hot out here.
120 motors were not too bad, something like a 50C differential between ambient and normal operating motor riding. Stalled traffic could see 90C or more in the timing cavity. Extreme days, over 100C. 180 series 1 were a different game all together, the reasons were not clear to me for the most part. Many of the usual components and adhesives did not last in the series 1 motors. Most damaging of all was the hot contaminated oil, over time. Reason why the wires fail in the series 1 bosch systems. The actual potted bosch 180 reluctors rarely fail, compared to lead in wiring. The "BTZ" style pickups however pull the centre pole faces, as many know here. That is a temperature problem for that pickup design, ie the plastic deforms over time.
Long storey short, the production IIS test jig could heat the Hall effect crank encoders up to 150C at cold crank speed to 6Krpm, response of encoders noted on a CRO to verify pulse shape specification to operate the control board correctly. Not only that, the crank encoder has to operate at least to 0C also, one IIS tested in the USA started the Laverda engine at about minus 28C, and unconfirmed minus 43C, way beyond the operating range of many semi conductors on the open market. While the IIS hall effect crank encoder board seems to be simple, many was the conflicting design problem to overcome. Then there is the vibration.... did i talk of the vibration..... and the shaking of components..... walking away scratching head.....and bum..... grin.
*BTW tested all the variations of cutouts on the series 1 alternator cover and inner casting, all rely on the motor in an air stream to work. Stuck way out there as it is... it is the stalled traffic condition that presents the most demands on design criteria.
HTH John.
