Moto Jouni is correct in that modern car engines have single use stretch bolts and when removing a head new ones are needed, but the torque setting for the bolts is only a primary means of tension, in most cases that I have come across, the "tightening" is finished by rotating the bolts (in the correct order) by a measured numbers of degrees, not by torque. And on Leyland "K" series engines (eg Metro, MGF, early Freelander etc) its even more complicated, because the head bolts are one and the same as the main bearing bolts, going right down from the top of the engine and into the sump where the bearing caps are retained, take the head off and rotate the engine at your peril!, its much the same for some UJM's, now there's a term you don't here much these days, it refers to universal Japanese motor, i.e. an across the frame four.
What about modern bike engines? they don't get re-torqued after XYZ miles, so how does that work? same principal?
technology??? I like the old stuff, give me a de-coke on a single cylinder side valve any day
