The purpose of the spigot lies within the design of the head itself and the head gasket. It should also be noted that 1000 pistons have a greater compression height than 1200 pistons. Dunno what there is to not understand...
The spigot indeed protects the gasket from taking the brunt of combustion pressure. It should reach to within a few 1/10 mm of the roof of the combustion chamber. It also fills in the ring-shaped void that could otherwise cause burn problems in regard to uneven heating of the chamber when using pistons of less than 80mm diameter. And it helps to uphold the compression ratio. The flanged edge of the liner should be 0.1-0.2mm lower than the gasket surface of the cylinder casting,
if using the proper original gasket with the slightly thicker flame rings! If only a gasket with uniform thickness is to hand,
the liner flanges need to be flush with the sealing surface! Over time, abuse and many, many heat cycles, the alloy of the casting actually shrinks, while the liners do not. This leaves the liners proud of the actual sealing surface, creating all manner of problems.
Apparently, the factory deemed the gasket capable of dealing with the mean pressures created by the 1200s lowly 8:1 compression ratio, and the spigot was omitted. The heads are identical! This called for a shorter piston, as it only rises to the height of the sealing surface, instead of above on the 1000s. The same regarding liner recession/protrusion holds here as well.
Due to the slight fuck-up by the gasket suppliers a couple of years ago, there is a huge stock of flat, uniform thickness gaskets. These are very handy for 1200 barrels that have been skimmed flat to rectify liner protrusion, no need to pull the liners and adjust the liner flange to correct the recess.
Imho, a solid copper gasket can
only be used sucessfully on a barrel with the liner flanges flush with the casting, any other condition will create similar problems to those of the "flat" gaskets.
All this has peviously been discussed at great length, I think there is a search button somewhere... :
