stand cylindes on the grid of the oven, with the protruding liners lowest, shut oven door, turn thermostat up to flat out, sit in armchair and drink a cup of (Keiths) tea a wait for a loud "clang" that is when the cast alloy has dropped over the liners and is now resting on the grid, remove items from oven with heat proof gloves. Turn oven off. You are going to wish that they were spotlessly clean and free from grease and debris if you did this when the old lady was out, because if you didnt she will know it ,right enough, and for about a fortnight
You did mark the liners before you removed them didnt you? because if they are not very badly worn it is possible to get a bit more life from them by rotating the 90 degrees before refitting.
refitting is another matter, patience and care is needed, plus a bit more kit
