Flywheels were the same from start to end, Craig.
Only difference was the water pump drive/ignition journal. Later cranks were even worse than the early ones in terms of shoddy workmanship!
There were (very) minor differences in the oil drillings in the crank pins, but all parts interchange without problems. Only the LH web is specific to build date, but can also be swapped for later type but will need the later ancilleries. The earliest would snap off the end where the ignition rotor is fitted.
Just as important is the balancer shaft, early ones also shit themselves big-time!
The cracking heads, etc, etc are signs of wear after 30+ years of use, the main bearing and skull-less heads issues were factory fumbles, have to admit that. The Zane engines have a definite "use by" date, after that, who knows??
Usually a case of the throttle cable coming undone because of the shoddy factory routing... potentially lethal!
chriskay said:I have heard of people on Zanes popping wheelies, and not being able button off. (Aye Cosi)
