D
Davo
Guest
Reading the thread on Q/A throttles and finding the twin cable Tomaselli on my new Le Mans 3 pretty darn heavy I did a little research and find that Dell Orto make various weight slide springs. Posts on Guzzi fora lead towards the use of the lightest spring for relieving throttle tension. This is a 0.7kg rated spring, with the heaviest spring at 1kg more than that.
Which springs are used in the dels on the Laverda triples and if it is the heaviest would a drop in spring weight work for reducing tension on the throttle, and therefore be easier on the hand.
All pretty academic for me as I am swapping to Miks, but just wondering, as you do.
Dave
Dave
