tom3c75
- Cape Town South Africa
Since rebuilding my series 1 Jota there?s been an intermittent and slight drip from the alternator side carb. Only seems to happen when the engine is hot. All the jets, seals, float needles & seats, etc. were replaced during the rebuild and the float levels were reset.
My first reaction was to tighten the float bowl nut and, when this did not help, to change the float bowl o-ring which, surprisingly, did show signs of wear. Also checked the floats for binding, etc.
During a ride over the weekend the bike started misfiring and when I stopped there was fuel pouring out of the suspect carb. I removed the float bowl, but found nothing amiss. However, I could not refit the bowl, as the rubber gasket, which had popped out of its groove, had expanded in length by about two cms! The thickness of the gasket seemed to be unaffected, but the material did appear softer. I cut off the excess length and placed the join at the rear high point of the bowl. This cured the leak and the misfire. I?ve now fitted a Viton replacement.
A few questions:
1. What else can cause the carb to leak/flood, other than the gasket, float height or a needle & seat problem?
2. Could the gasket, which clearly was not fuel resistant, have allowed fuel past the sealing surfaces, or even
have become dislodged, while the float bowl was in place?
3. Is there a vent hole/overflow on these earlier Dells and, if so, where is the vent?
4. What is the preferred method of adjusting the float level? The Dellorto manual says to bend the float arms,
but some folk say to adjust the tang that the float needle rests on.
Thanks
Tom
A few questions:
Thanks
Tom
