What's a TMR, Lothar? Did you mean FCR? I know the Keihin FCRs run with rollers for the slides. Didn't know about a Mikuni having that.
No, I meant the Mikunis. They have different ones:
RS: "budget" flat slide carbs with sliders sliding in a passage; no rollers, no adjustable accelerator pump. More than enough for street usage and a big improvement over the Dell'Ortos in any regards.
TM: originally designed for two stroke engines but can be used on 4-stroke, too, with the right jetting
TMR: the top end product of 4stroke engine carbs with steel rollers, choke, adjustable accelerator pump etc. Great to get the last bit out of your engine and improve even further the forces needed to open the carbs etc.
TDMR: same as TMR but layout as downdraft carbs (for very steep inlet angles, not usable on our bikes).
TMX: High end 2-stroke carb for racing applications mainly
HS & HSR: Harley single carb kits
VM: round slider carbs with modern design. usable for certain race classes, where flat slide carbs are prohibited.
So - basically, for Laverda there are RS or TMR, both in 36mm, both configured for Laverda available at Steven Topham in Germany f.e., and I assume there is a reason for that:
Price-difference between the TMR and RS are 400€. Your choice ;-)
Regarding the acceleration pumps used for starting: Do yours not have a choke system?!? Mine do...
