Disassembly of Flywheel/Starter clutch, 750 SF
Jotabene
Hi,
I have a problem with my flywheel. Three out of the six small spring loaded pusher rods are stuck in their holes i.e. no spring force on three of the rollers.
I plan to dismount the flywheel and overhaul it. But how to get the "guiding ring" out of the flywheel? There is nothing really to "hook" on to to pull it out.
Anyone having experience of flywheel mount disassembly? Any advice is appreciated.
I drilled one or two 5mm holes as far through the soft outer casing before hitting the inner part and then used a flat ended punch to carefully knock out the hardened inner part.  Didn't need to use a slot drill as the drill left only a very thin skin to knock through - regards - Phil
