Hi Witt fans.
I'm fitting a DMC2 to an SF0 and have brain zone-out on setting the rough timing.
Instructions say.
1) Motor at TDC
2) Get it sparking - i.e. photocell seeing through gap.
3) Turn photocell clockwise until sparks just stop.
4) You have a rough static timing - do you dynamic checks from here.
I can't get that. My open and shut situations seem to be different to Uwe's. When I set the general arrangement is as per the sketches in the instructions. ?
My scenario 1
1) Motor at TDC
3) Turn photocell counter clockwise until sparks just stop.
My scenario 2
1) Motor at 40?BTDC
Both scenarios have a very similar baseplate setting, so no clues there.
When I try to achieve Uwe's instructions, the 3 x fixing slots do not line up.
I am taking 'photocell clockwise' as being viewed from the LH side of the bike. If Uwe means from the RH side, then that would explain it.
Thoughts? Tips? Where did I goof?
Instructions say.
1) Motor at TDC
My scenario 1
1) Motor at TDC
My scenario 2
1) Motor at 40?BTDC
