Ooolie doolie, Chris ... and I thought i did some pretty wacky mods to my SF!! Love to hear how the Suzerda GSFX-R felt on the road and how it handled a doubling of Rr wheel HP. Actually I think I beat you to the punch - I put a GSX-R J(? two round headlights and inlet tracts) model fairing on my SF about 18 years ago ... set it up with the full fairing but only ran the top half ... it's supposed to be mated to an RGS tank (fibreglass dummy cover over a stainless tank) - but I needed to ride on it and
When I fitted 17 inch wire wheels (4.25 inch rear Akront) to mine I originally ran a 140 (too small) then a 150 (just right baby bear) and then was told a 160 would work on that rim size - no, too big; sidewalls ended up looking like one of those original Avon Roadrunners - impossible to lean it that far! And with the 160 the chainline was too narrow, so I went the offset sprocket (maybe 5mm from memory). Was thinking of 5 inch supermotard rim but too much hassle - I'm going back to the 150.
To go to 180 you'll need at least 15mm from std, to go 200, add another 10mm.
I toyed with the idea of shifting the donk right and I reckon the weight bias L-R would be better (a lot of weight on the left drive assembly (plus I've got a GPX1000 alternator fitted so lose about 3 kg!). I'm pretty sure cornering clearance is better on the right as std - only ever dragged the bolt on the lower selector cover once on the track (when running 18s), but not sure on that.
Let me know how you go. And BTW, spreading the frame under the tank to get longer inlet tracts for my Keihin FCR 39s is another idea I floated when I should have been sleeping! I'm running out of years for all these mods!
I like the look of that swingarm - what's it off? I have a Yamaha Deltabox and monoshock off an FZR ... another deadend idea I think!!
QF
