Hi peeps,
Can someone please explain to me how the wiring of the temperature switch on my Corsa is meant to work?
Here?s the relevant bit of the wiring diagram. I've hi-lighted the violet wire that goes between the switch and the terminal block that is next to the rev counter. And the gauge in the instrument panel is, unsurprisingly, connected to the other side of this terminal block.
I assume that the switch goes to ground as/when the temperature rises.
So where does the power for the circuit come from?
What am I missing/failing to understand here? :-[ :-[ Gotta be something blindingly obvious ...
TIA
Craig
(The other connections at the terminal block are the indicator idiot light; the full beam idiot light; the rev counter feed from the coil).
TIA
Craig
