You don't understand Bob.
The classic billy cart comprises of a 2x2 front axle, crudely chopped away at the ends to accomodate a large(ish) ball bearing, secured firmly with a handfull of bent-over 3" nails. A 4x2 builds the backbone onto which the front axle is "attached" by a rusty 1/2" bolt and nut, along with a couple of large, preferably rusty, washers. The axle is only attached loosely and a loop of rope/string fixed to either end takes care of the steering. The rear solid axle also carries a pair of ball bearings attached in a similar mode to the front, only this axle doesn't swivel. A bit of chip board or masonite affords adequate seating. All you then need is a steep hill and large enough balls and away you go! Crikey, how often I hurt myself, and others, with these contraptions is unbelievable.
What you've got there isn't a billy cart, that's the fuckin' Bluebird!!
SFC-Bob,
No, nobody from 883 racing, although we did adjust the wheel bearings on the loose side. The guys doing the Yamaha Cup, first XS400, then 350 YPVS were always investigating how to squeeze another 0.26km/h from their machines. The bikes were so equal and rider skill usually was enough for the limited performance of the bikes, any outside chance was quickly siezed!
SFC-Bob,
