S Smartv11 Full member Location Meopham, Kent Feb 20, 2017 #1 Q - Is earthing a wire in the headlight shell a good earth point? Paul
phil37 Hero member Location Lincolnshire Feb 20, 2017 #2 A - not really - some are fully rubber mounted - regards - Phil
D Davo Guest Feb 20, 2017 #3 A2 - It is if you run an earth wire from the headlight shell back to the common earth.
jotajoe Hero member Location Warwickshire UK Feb 21, 2017 #4 Davo said: A2 - It is if you run an earth wire from the headlight shell back to the common earth. Click to expand... Good hint Dave. Id thought of making a earthing bus bar inside the shell but your idea has same result as the return will find the easiest path. Ive read that the head bearings can be damaged through being used as a pathway. Joe
