The Zane crank project has gone to shit at the moment, but I?m regrouping and moving forward again with that soon. It?s got something to do with a hot summer and the money tree down the back is not bearing a lot of fruit.
And I?m writing a story for the Easter Bunny?.
So I?ve been mucking around with a 3CL project I have. Totally stock 78 3CL, not been started for about 80 years. I fired the motor up a couple of months ago on an ignitec with 0 degrees base timing. It fired within one revolution, and idled. (i've got video to prove it).
I didn?t overhaul the carbs at all, just set the floats and replaced the o rings on the idle? jets. You?re all cringing already?
Valve clearances were a bit tight, but no point setting them until the motor has run for a while. Compression was something like 150/160/150, I think..
I did put new oil in it!!! And our Guru helped me with a map that started at 8 degrees?.
I figured that hard rubber tips were no different to the old brass needle and seats that I started life with?.
So, armed with an electronic ?mercury? guage, an infrared temp guage, a sniffer, and a couple of 6 packs I decide to tune the motor?..Hmmmm.
I am not good (ie shithouse) with tuning Dellortos, even though I have managed to my Guzzi?s running ok in the past.
I?ve now taken 3 bowl holders and set them up with tubes to check float levels. It doesn?t matter how much I try to set float by ruler, it does not work. Currently I have 2 carbs at about, using a spirit level from the front of the bowl/carby line, at about 4mm above, 1 at about 10mm above. They are consistent with the running of the motor, so old rubber tips are working ok?Comments?
I?m getting it to idle, but back firing at times at idle, and out of balance at idle, is an issue. Once on the throttle a bit balance is spot on the bench and backfiring goes away. There is no adjustment for idle position, and if I balance them at idle on the rail screws, they are out of balance once the throttle is cracked.
Another current post asks about cold/hot idle. I concur with these old bikes need to warmed up. This one is the same.
So, some questions?.
Q)If bike idles ok, then dies back and stalls after a minute or so, that is the idle mixture is too rich? (chokes etc checked). The idle screw is a fuel adjustment, not air ( as per the other thread), so is the best adjustment max rpm at idle? In this case about 2 turns.
Q)Leaking exhaust copper O rings. What effect does that have?
Q)Not having clamps on the 3 to 2 exhaust system. What effect does that have?
Q)Spark plugs that have fouled because it is all too rich, and are tracking down in the plug. Is the best way to clean them is in the blasting cabinet???
Q)The NGK caps for the plugs. How does one test them reliably? The coils on cylinders will throw a spark about 15 to 20mm, but fit the NGK caps and the spark looks weak. Does the Invitec impact on this. I?m using the Ktek coils (?) of a Kawasaki (?)
Q)Once the motor is hot the best I can get on the sniffer at idle is about 27:1, not the stocky o metric of 12.7:1, but then it is stuck down 1 or the other pipe measuring 3 cylinders?What stocky o metric value should this run at at idle??
Q)Given the tools I have, what is the best process to get this old girl running correctly?
Merry Easter to you all, may you enjoy the time with your families!!!
Regards to all on the Forum,
Greg
PS If you see a pink Easter Bunny that?s been run off the road, don?t stop. The real Easter Bunny is white.
Greg
