D
Davo
Guest
Has anyone tried this stuff. Looks too good to be true. https://hyperowl.shop/products/super-melt-welding-rods?fbclid=IwAR2M9rKinppBYwLBGMWXKMrPrQR1rHQrBa20MGG7jR5K2G-12X5l_KeXflM
Lav the impala said:I'm sure they are pure zinc, mainly used for repairing diecast.
Davo said:Supposedly aluminium/magnesium mix with built in flux granules.
Davo said:I was thinking it may have application for repair of crankcase cracks/holes in non-load bearing areas as the amount of heat required and the way it is applied would not distort the case.
Grant said:Laser welding would be a better option there.
Dellortoman said:According to their website the rods are a tin/zinc alloy. Different alloying percentages are available for different fusion temperatures. 91% tin with 9% zinc is the eutectic mixture (lowest melting point). There's also a tin/zinc/lead rod for cast iron repair.
