Engine to Frame torque settings
critter39
Just got the motor back in the frame can't find any torque settings for the frame to engine bolts if any one can help also swing arm spindle torque is there a page on the forum with this info. Cheers chris
Thanks Paul used flat washer spring washer nylocks,is the swing arm pivot bolt the same just bloody tight, by the way it's an sf2
Is your swing arm still on bronze bushes? Not that it affects spindle tightening. Yes, bloody tight as well checking that arm is free to pivot.
