Yesterday I put the 182 mains in and also the Dynojet adjustable needles I bought a few years back and also the thinner air filter I made.I really hate pulling the CV side and bladder out,its a real pain to put back right and not damage the little rubber loop bit.I set the needle to be fully down or at its leanest.A quick spin around the block proved that wouldn't work.It now had a big miss just off idle,to I raised the needle 3 from the bottom and did another ride,much better.Its a absolute pleasure when jetting to get a definite effect from a change.I spent a long time playing with jetting trying to fix a cam timing issue a few year back.That's why I had the Dynojet kit,its designed for a Honda CB1000 Big,that's what the carbs are off and I am now happy I bought the kits.So today I did a 120k lap of The Old Rd as an test,It was a peach of a day up there.What with the footy final on,Double Demerits applying for the long weekend I was almost alone up there.On the road the bike performed very well,its hard to tell how the main jet change works,it still pulls like a train.The only problem I can feel is with the leaner setting of the Dynojet needle it seems slightly weaker pull just off idle.It still lugs well,just not as well as before with the std needle shimmed up with 2 washers.Time for another dyno run I think,problem is its going to have to be another Dyno as the one I have been using has been sold and its replacement is a month off,to late for me to prepare for The Snowy Run.At least I will confirm the AF ratio.
