fitting the primary chain tensioner
treoleileagh
Australia
For a triple, has any one got a good tip for holding the spring in place while the cover is being fitted. As I lift the cover to fit it, the spring seems to be twisting and distorting, or even falling out its hole in the tensioner slipper.
Thanks
Found it. Cheers Andre. I gather the shaft that locates the slipper can be removed from the engine case and fitted into the cover before assembly. i'll try that tomorrow. Many thanks
Good you found it. As I am on a business trip I did not want to typ the full procedure in my mobil phone  :)
