Paddy said:I wonder how important float hight really is ? Its going to alter with lean angle, acceleration and deceleration. In my world of bevel ducati's the float hight is given as an exact but TBH the front carb is angled at about 45 degrees and leaning on its side while the rear is horizontal and level.
what is really important is the fuel level in the emulsion tube which being in the centre of the float bowl (ish) will remain pretty constant, for this reason some sort of manometer would be the answer, some Dellorto's do have a drain plug that can be used to attach a manometer tube.
Why don't you drop it by 2mm and see how quickly you can hole a piston at WOT?
Fuel level in the emulsion tube is directly connected to float height. Float height is the easiest thing to check half-accurately while the carb is off the engine, so gives a close-to-ideal setting for the ensuing fuel level. Having all carbs in the same plane is a definite advantage, having them at different angles opens a new can of worms... perhaps it may be an advantage to use manometer tubes in that case.
Ideally, the fuel level should stay constant at all times and there should be no sloshing around in the float bowl while cornering or accellerating. The main reason fuel injection is so much
