Scrumpy
I have just purchased some ceriani forks to fit to a series 1 Jota from Ebay. I received them today. On inspection I found that there was no up or down movement in them. One of the fork legs sat 8mm proud of the top yoke. Releasing the pinch bolts I was unable to push it down, I suspect due to possible corrosion under the headlamp shroud. I removed the wheel spindle which enabled one fork leg to move as expected, the other moves about 2mm before coming up against a positive stop.
Overall the forks appear in good condition, using a straight edge and under artificial light I can not identify any inconsitencies in the fork tubes. Both revolve in the yokes and both sliders rotate freely.
The seller has offered me my money back if not satisfied with the goods. Naturally I want to keep them after waiting for some time for a set of forks to become available. They have been sat in his garage for 3 years, I have not used any force yet or removed the top nuts to look inside. Any suggestions would be appreciated.
Scrumpy
Scrumpy
