fork seal laverda 125 lb strada
RonnieT
Hello people,
Today I discovered some oil on the fork of my motor (Laverda 125 lb strada from 1984). After cleaning it and pushing the motor in its suspension, some oil crept out of the fork. So now I'm looking for a new seal. unfortunately I can't find any.
Does anyone know which other types have the same fork and thus seal? Because I can find them for other models but don't want to buy one which doesn't fit.
A simple way of getting around this is to accurately measure the stanchion diameter, the outside diameter of the existing seal and have a guess at the depth of the seal at either 6mm or 7mm if it's still in the slider then go down to your nearest bearing/seal dealer (Yellow Pages) and you should be lucky. What he can readily get you will probably not have the 'upward' facing lip but should do a good job of stopping the oil getting past. Best of luck.
Where in the world are you?
There are a handful of Laverda specialists dotted round the globe. Not sure if all cater for the small ones though.
Well, you could just take a peek in the parts book... waddaya mean, you don't have one? :D
LB1 fork seal, part# 55 216 442, Guarnizione MIM3242/7, makes it 32mm x 42mm x 7mm.  Same item for Sport and Custom, so I'm guessing the Strada has the same as well.
If you give me a day or 2, I can supply them.  I ship worldwide, even to the moon if you can arrange pay for it! :D
