Andy, the tension is done manually, book says 5mm of movement up and 5 down, 10mm o/a measured between the cam sprockets. I check my valve clearances every 5-8000 kays so the chain gets checked as well. Same proceedure for the last 26 years and first time to encounter this problem. I usually like to change cam chains every 15k,
factory specs say 25k if I'm not mistaken.
