Front brake cable nipples (for laverda brake)
Smartv11
Meopham, Kent
I've just received a new brake cable from well known UK supplier, and surprised by the different nipple (hexagon shape) compared to my barrel nipple.
At first i though it was simply an incorrect cable but checking a few pics on the web (Laverda Paradise) shows this may not be the case. Anyone have some clarification on why there is a difference?
I need a barrel nipple as this hexagon shape does not fit.
You need a barrel with a slot and relief in it so the hex part fits inside it [perpendicular to the barrel] . It keeps the cable end from flexing and breaking with use. Common on most cable clutches.
apparently as I'm missing the front brake light switch mechanism, i'm also missing a barrel that the hexagon slots into!
If any one could kindly provide a photo of front brake light switch (cable operated) and associated bits, i would be grateful.
I have been told that my '69 750 does not need a front brake light switch for its one and only MOT (see other threads) The rear brake light switch works fine.
If it was fitted it would have to work.
