Thanks for this.
The long overdue job of getting the MK1 back on the road has officially begun.
Rear disc replaced.
Rear caliper overhauled.
Oil changed.
Horn replaced.
All lubed and cleaned up a bit, just need to save up for a decent battery, any recommendations? don't think the optimate is ever going to bring the old lead acid one back to life
they may have run out of the 7mm x 12mm but I just received 5m of the 7mm x 14mm and it should do the job with some of those nice S/Steel hose clips shown earlier (50p each from my local hydraulic supplier)
I've got 10m of this http://www.piaggiospares.co.uk/spares/partImage.asp?GPN=VE00071&uID=0 but I believe Red also has a supply of Cavis lookyloo. It may be cheaper postage from his side of the island than from Perth. If you have no luck let me know and I will flick some your way.
